Read xml and redirect traffic
Hi, somebody can help me, I need read the value of a error in xml code, and with this information makes a traffic redirection, there is a sample of the code:
soapenv:Body> error="0"><tx nbreq=1><req name=insert ver=7.0.11 state=undefined><ent name=Subscriber ns=policy><set><expr><attr name=AccountId><op value="="><value val=TestUser1Lab></value></op></attr></expr><expr><attr name=MSISDN><op value="="><value val=0057123456789></value></op></attr></expr><expr><attr name=IMSI><op value="="><value val=508414170000000></value></op></attr></expr><expr><attr name=BillingDay><op value="="><value val=1></value></op></attr></expr><expr><attr name=Entitlement><op value="="><value val="Mail Service Package"></value></op></attr></expr><expr><attr name=Custom1><op value="="><value val=postpaid></value></op></attr></expr></set><res <strong>error="0"</strong> affected="1"></ent></req></tx>
Is there any way to read the information marked in bold and store in a variable? Thanks for your comments
- Lee_Sutcliffe
Nacreous
This may do the trick.. but not sure if it's exactly what you're after:
when HTTP_REQUEST { set xml_error "error=\"0\"" } when HTTP_RESPONSE { if { ([HTTP::header value Content-Type] contains "text/html" )&& [info exists xml_error] } { << - re-direct - >> } } - stan_piron
Cumulonimbus
You can use a stream profile with this type of irule :
when HTTP_REQUEST { Disable the stream filter for all requests STREAM::disable } when HTTP_RESPONSE { Check if response type is text if { ([HTTP::header value Content-Type] contains "text/html" ) Match an http://*example.com string and replace it with nothing yet STREAM::expression {&<\w* error=\"0\">&&} Enable the stream filter for this response only STREAM::enable } } when STREAM_MATCHED { Check if the matched string meets some condition that can't easily be checked for using a single regex in STREAM::expression if {[STREAM::match] starts_with " - Guillermo_Ferna
Hello, the question is because we are receiving traffic from several server that makes request to an appliaction, now the f5 must receive this traffic and develop a load balance based on conection numbers, but the problem begins when I got the answer from the application, this response is based on xml code, and we need read the error level value on the response for make a decision for redirect traffic to another pool member.
can you help me?
