Re-routing with SSL problem
Hi there
I'm a newbie with LTM and have been struggling with following some time now, with no success...
I have two servers in a pool with load balancing and SSL decryption at LTM. Everything is working just fine but what I would like to do is the following...
I'd like to add another node(s) to where I'd like the end users to be rerouted by link on a main site (or string returning to their browser). I have a VIP and virtual server that decrypts SSL and forwards it to actual application servers. I have managed to get re-route work with just HTTP but I'd like to re-route traffic encrypted from browser to LTM.
Please advice
perhaps i don't understand your question fully. but this sounds like a simple second pool to which traffic is send when the client goes to a specific URI.
so for example
https://domain.com/ --> pool1 https://domain.com/special --> pool2
for that you can use iRule or local traffic policy.
is that what you want?
- Esa_H_192976
Hi and thanks for the help... Indeed, that is what I really would like to have, but somehow I just can't get it to work.
the example:
Pool 1 contains server1, Pool 2 contains server 2...
- https://domain.com --> should go to pool 1.
- if a link on server 1 contains "Tequila" (https://domain.com/tequila) ---> should go to pool2
- if a link on server 1 contains "Whiskey" (https://domain.com/whiskey) ---> should go to pool3 ... an so on
and...
- if a reply from server contains e.g. username "Homer" ---> should go to pool4
I have this kind of an iRule... (copied from Devcentral)
when HTTP_REQUEST { log local0. "request received" if { [string tolower [HTTP::uri]] starts_with "Tequila" } { log local0. "request for service received. Selecting end server" pool Pool2 } elseif { [string tolower [HTTP::uri]] starts_with "Whiskey" } { log local0. "request for service received. Selecting end server" pool Pool3 } else { pool Pool1 log local0. "Condition not matched. to Pool 1..." } } when SERVER_CONNECTED { log local0. "Connection from [IP::client_addr]:[TCP::client_port] to 2. server: [IP::server_addr]:[TCP::server_port] established." }Somehow it just not work properly the connection is taken to wrong server of not at all
Esa
- well the combination string to lower with a comparison that contains a Uppercase letter wont work of course. start with changing that, i.e. : if { [string tolower [HTTP::uri]] starts_with "tequila" } {
- Esa_H_192976
Hi again... thanks... I got a little futher with an issue. I will return with some new issues later.
