Jerry_Bruce's avatar
Jerry_Bruce
Sep 24, 2019
Pulse Secure - ESP switching to SSL after timeout
Does anyone have experience with setting up an Active/Active pair of Pulse Secure PSAs behind the F5 using LTM? We have a VS set-up with access to the backend appliances. The Pulse client connects successfully using SSL initially, switches to ESP, then falls back to SSL after reaching the timeout of 15 seconds which is the default on the PSA. We have a persistent profile configured for the VS that is configured for UDP:4500. There is no firewall that is blocking UDP:4500.
Any suggestions?
  • We were able to solve this. We determined that UDP:4500 was being blocked from the F5 to the external interfaces on the cluster. Once the traffic was being allowed the sessions would still not maintain an ESP connection until we disabled the SPI lookup
    modify sys db ipsec.lookupspi value disable
    (K14169).
