Amy_Allen_570
Feb 14, 2007Problem with state status after toggle
Hello all,
I am having problem when I use togglePoolMember.pl to change status of member's state. For example, when I run togglePoolMember.pl, state status change to DISABLE from ENABLE. But, when I run getMemberInfo.pl for the same pool and member, I got state ENABLE. Is there anybody else seen this problem? I am not sure where the problem is. Need help. Thanks!
- Amy_Allen_570
After some more testing, I found that togglePoolMember.pl doesn't change the status of the state. - Could you post the output when the SOAP debugging is turned on?
use SOAP::Lite + trace => qw(method debug);
This will output all the SOAP messages and their responses. You can omit any connection info that you deem confidential. I'm primarily concerned with the SOAPRequests and SOAPResponses. Also, if you could provide the command line arguments you passed in (minus address/username/password) that would help as well.
-Joe - Oops, make that:
-Joe - Amy_Allen_570
The command I use istogglePoolMember.pl xxx.xxx.xxx 443 username passwd poolname 192.x.x.1
Here is the SOAP debug:SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" > > xmlns:namesp1="urn:iControl:LocalLB/PoolMember" > SOAP-ENC:arrayType="xsd:string[1]" > >amytest.usg-http SOAP::Transport::HTTP::Client::send_receive: HTTP::Response=HASH(0x8630d30) SOAP::Transport::HTTP::Client::send_receive: HTTP/1.1 200 OK Connection: close Date: Wed, 14 Feb 2007 19:42:38 GMT Server: Apache Content-Type: text/xml; charset="UTF-8" Client-Date: Wed, 14 Feb 2007 19:42:39 GMT Client-Peer: x.x.x.x:443 Client-Response-Num: 1 Client-SSL-Cert-Issuer: /C=US/ST=TX/L=Denton/O=xxxxx/OU=xxxxxx/CN=xxx.xxx.xxx/emailAddress=xxxx@xxxx.xxx Client-SSL-Cert-Subject: /C=US/ST=TX/L=Denton/O=xxxxxx/OU=xxxxxx Group/CN=xxx.xxx.xxx/emailAddress=xxx@xxxx.xxx Client-SSL-Cipher: DHE-RSA-AES256-SHA Client-SSL-Warning: Peer certificate not verified Client-Transfer-Encoding: chunked Set-Cookie: BIGIPAuthCookie=BD685D5053281572914BAA28AAE59C0C764846F8; path=/; Secure; SOAPServer: EasySoap++/0.6 xmlns:E="http://schemas.xmlsoap.org/soap/envelope/" xmlns:A="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://www.w3.org/2001/XMLSchema-instance" xmlns:y="http://www.w3.org/2001/XMLSchema" xmlns:iControl="urn:iControl" E:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> xmlns:m="urn:iControl:LocalLB/PoolMember"> s:type="A:Array" A:arrayType="iControl:LocalLB.PoolMember.MemberSessionState[][1]"> A:arrayType="iControl:LocalLB.PoolMember.MemberSessionState[4]"> s:type="iControl:LocalLB.PoolMember.MemberSessionState"> s:type="iControl:Common.IPPortDefinition"> s:type="y:string">192.x.x.1 s:type="y:long">80 s:type="iControl:Common.EnabledState">STATE_ENABLED s:type="iControl:LocalLB.PoolMember.MemberSessionState"> s:type="iControl:Common.IPPortDefinition"> s:type="y:string">192.x.x.4 s:type="y:long">80 s:type="iControl:Common.EnabledState">STATE_DISABLED s:type="iControl:LocalLB.PoolMember.MemberSessionState"> s:type="iControl:Common.IPPortDefinition"> s:type="y:string">192.x.x.2 s:type="y:long">80 s:type="iControl:Common.EnabledState">STATE_DISABLED s:type="iControl:LocalLB.PoolMember.MemberSessionState"> s:type="iControl:Common.IPPortDefinition"> s:type="y:string">192.x.x.81 s:type="y:long">80 s:type="iControl:Common.EnabledState">STATE_ENABLED SOAP::Deserializer::deserialize: () ... SOAP::Data::new: () SOAP::Data::new: () SOAP::Data::new: () SOAP::Transport::HTTP::Client::send_receive: HTTP::Request=HASH(0x8736984) SOAP::Transport::HTTP::Client::send_receive: POST https://xxx.xxx.xxx:443/iControl/iControlPortal.cgi HTTP/1.1 Accept: text/xml Accept: multipart/* Content-Length: 1319 Content-Type: text/xml; charset=utf-8 SOAPAction: "urn:iControl:LocalLB/PoolMemberset_session_enabled_state"xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:namesp3="http://namespaces.soaplite.com/perl" xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsd="http://www.w3.org/1999/XMLSchema" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" > > xmlns:namesp2="urn:iControl:LocalLB/PoolMember" > SOAP-ENC:arrayType="xsd:string[1]" > >amytest.usg-http SOAP-ENC:arrayType="SOAP-ENC:Array[1]" > > > > >192.x.x.81 >80 >STATE_DISABLED SOAP::Transport::HTTP::Client::send_receive: HTTP::Response=HASH(0x8735814) SOAP::Transport::HTTP::Client::send_receive: HTTP/1.1 200 OK Connection: close Date: Wed, 14 Feb 2007 19:42:39 GMT Server: Apache Content-Type: text/xml; charset="UTF-8" Client-Date: Wed, 14 Feb 2007 19:42:39 GMT Client-Peer: x.x.x.x:443 Client-Response-Num: 1 ... Client-SSL-Cipher: DHE-RSA-AES256-SHA Client-SSL-Warning: Peer certificate not verified Client-Transfer-Encoding: chunked Set-Cookie: BIGIPAuthCookie=BD685D5053281572914BAA28AAE59C0C764846F8; path=/; Secure; SOAPServer: EasySoap++/0.6 xmlns:E="http://schemas.xmlsoap.org/soap/envelope/" xmlns:A="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://www.w3.org/2001/XMLSchema-instance" xmlns:y="http://www.w3.org/2001/XMLSchema" xmlns:iControl="urn:iControl" E:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> xmlns:m="urn:iControl:LocalLB/PoolMember"> SOAP::Deserializer::deserialize: () SOAP::Parser::decode: () SOAP::SOM::new: () SOAP::SOM::DESTROY: () Pool Member poolname {192.x.x.1:80} state set from 'STATE_ENABLED' to 'STATE_DISABLED' SOAP::Data::DESTROY: () ...
I have 4 member in this pool.
Available pool members
pool poolname {
192.x.x.1:80 (STATE_ENABLED)
192.x.x.4:80 (STATE_DISABLED)
192.x.x.2:80 (STATE_DISABLED)
192.x.x.81:80 (STATE_ENABLED)
It looks like it is only toggle the last member in the pool. - Looks like there is a bug in the logic in that sample. I'll take a look and see if I can get a fix posted.
Thanks a lot. It fixed the problem.
