JimmyJose's avatar
JimmyJose
Feb 24, 2016
Pool selection using iRule
Hello,
An application is hosted on ports 8443 and 8445.
I am trying to achieve the following using iRule.
Tried the following 2 iRules. Observation is that the redirect to https://abc.domain.com/123/456 is attempted, but fails.
if {[HTTP::uri] equals "/"}{HTTP::redirect "https://[HTTP::host]/123/456" pool POOL-1} elseif {[HTTP::uri] ends_with "/999/*"}{POOL-2} }
when HTTP_REQUEST { switch -glob [string tolower [HTTP::uri]] { / {HTTP::redirect "https://[HTTP::host]/123/456"} /123/456 {pool POOL-1} /999/* {pool POOL-2} } }
when HTTP_REQUEST { switch -glob [string tolower [HTTP::uri]] { "/999/*" { pool POOL-2 } "/" {HTTP::redirect "https://[HTTP::host]/123/456"} } }
and in this case, set the default pool to POOL-1 in the virtual server.
Am I making any mistakes in the iRules?
-Jimmy
  • If you specify POOL-1 as the default pool, then I'd use the last iRule like this:
        log local0. "Host: [HTTP::host]"
        log local0. "URI: [HTTP::uri]"
                log local0. "  /: Redirect to /123/456"
                HTTP::redirect "/123/456"
                return
            "/999/*" {
                log local0. "  /999/*: Pool POOL-2"
                pool POOL-2
    If you're having trouble with request, then you could check it from the CLI using
    curl
    to see if the url works (just to verify it's not a web server issue). So something like
    curl -k https://:/123/546 -v
    (or use http if you're offloading SSL and going HTTP to the web server)
