Alan_Millar's avatar
Alan_Millar
Jul 24, 2019
Solved
IP Filtering using Xff-clientip in iRule
We are currently using IP filtering for URIs like this:
  }   elseif { ([HTTP::uri] starts_with "/site") and ( [class match [IP::client_addr] equals  management_IP])} {
      use pool pSite
However we just started passing the traffic through a web security provider, so the source IP addresses are now the security provider IP. Is there a way we can use the X-Forwarded-For IP address in this kind of filtering?
  • You are right Stan! Thanks for the contribution.
    , here is the new code:
        if { ([HTTP::uri] starts_with "/site") } {
            if {[HTTP::header exists "X-Forwarded-For"]} {
                set clientIP [string trim [getfield [HTTP::header value "X-Forwarded-For"] "," 1] " "]
                if { ([class match $clientIP equals management_IP]) } {
                    pool pSite
                pool pSite
    KR,
    Dario.
  • Hello Alan.
    Try with this code:
                set clientIPList [split [HTTP::header value "X-Forwarded-For"] ","]
                set clientIP [lindex $ipList 0]
                    pool pSite
                pool pSite
    KR,
    Dario.
    • stan_piron's avatar
      stan_piron
       2 optimizations to your code:
      • use getfield command instead of split / lindex
      • use string trim command on the result to make sure there is no space before the comma
      • Dario_Garrido's avatar
        Dario_Garrido
        Icon for Noctilucent rankNoctilucent
                        pool pSite
                    pool pSite
        KR,
        Dario.
