Samit_jadhav's avatar
Samit_jadhav
Aug 15, 2020
Pool members aren't coming up after applying https monitor to the pool
Pool members aren't coming up after applying https monitor.
Send string : GET /BrowserWeb HTTP/1.1\r\n
Receive string : 200
Could anyone assist. Thanks!
  • Hello Samit.
    Three steps for troubleshooting:
    1) If it were possible, check with a HTTP monitor using the same config.
    2) Use curl or openssl for checking if the response is correct (200 OK).
    # curl -kv https://<server>/BrowserWeb
    # echo -e "GET /BrowserWeb HTTP/1.1\r\nHost:<server>\r\n\r\n" | openssl s_client -quiet -connect <server>:443 2>&1
    Note: replace <server> with the IP or hostname.
    2) Capture traffic using tcpdump or ssldump to check that no SSL error are occurring.
    Regards,
    Dario.
  • First just check if node have any monitor (maybe default). If node monitor failed, pool will be down even if pool monitor status is ok.
