Pushkar_73645's avatar
Pushkar_73645
Aug 23, 2010
php based solution of icontrol
I am trying to write an php script to enable and disable nodes.
I was trying to use following call. I get $serv value from my previous call to LB which get list of all servers.
I see myself entering the loop. But the node is not disabled.
if ($serv == "192.168.100.50"){
echo "test";
$client3->set_monitor_state($serv,"STATE_DISABLED");
Thanks,
Pushkar
  • set_monitor_state method takes an array of nodes as a first parameter, not a string, check out the API documentation:
    http://devcentral.f5.com/wiki/default.aspx/iControl/LocalLB__NodeAddress__set_monitor_state.html
    You will also need to disable the session state using set_session_enabled_state in order to disable the node
  • Thanks.
    It requires both node address and session enabled state as an array. It works for me now.
    Another question ralated to this is that when i disable using set_monitor_state and set_session_enabled_state, the node goes into Forced Offline mode.
    Is there a way of changing node state to Disabled and not Forced Offline?
    Enabled (All traffic allowed):
    set_monitor_state : STATE_ENABLED
    set_session_enabled_state : STATE_ENABLED
    Disabled (Only persistent or active connections allowed):
    set_session_enabled_state : STATE_DISABLED
    Forced Offline (Only active connections allowed):
    set_monitor_state : STATE_DISABLED
  • Pushkar,
    Can you post the PHP code you used for setting up your arrays and calling set_session_enabled_state and set_monitor_state?
    I got the set_monitor_state working (I think), but I can't seem to get the set_session_enabled_state function called correctly.
  • $servers = array(0=>$server);
    $state = array (0=>"STATE_DISABLED");
    $client3->set_monitor_state($servers,$state);
    $client3->set_session_enabled_state($servers,$state);
    I am just trying to disable 1 node at a time.
  • Thanks! Unfortunately, it doesn't seem to work for me. I assume $server is the node address? What about for disabling a pool member? Have you tried that at all?
  • yes $server is a node address.
    I have unsuccessfully tried to disable pool member. still trying to troubleshoot it.
