DaveC_53879
Oct 04, 2011Persistence problem
I have an iRule in place that is logging clients that do and do not submit persistence cookies for a particular site as one customer is regularly losing persistence, sometimes being directed to another server in rotation, and losing all session info which generates a time-out and forces them to re-authenticate. I can see in the logs that many exisitng sessions from this customer will stop presenting the persistence cookie for a few seconds, may or may not get kicked out, and then start working correctly for a few minutes. This can happen with one or more clients from the same address and usually effects everyone currently connected form that one customer's space. Not sure if this is the right place to ask, but what can be causing this? I'm using an encrypted cookie with a 20-minute time-out, but the failures are happening before the time-out. So far I have not been able to talk to the customer's IT folks. Thanks for looking.
- nitass
Employee
is it possible to run httpwatch while reproducing the problem? - Michael_Yates
Do you know if this is happening from a large IP Space (entire subnet or is the customer behind a NAT)?
The problem that you are having sounds very similar to one that I have seen before and was resolved the the use of the OneConnet Profile.
http://devcentral.f5.com/wiki/AdvDesignConfig.OneConnect.ashx - DaveC_53879
So far we haven't been able to get anyone technical on the other end to help us troubleshoot this issue. I'm sure we could figure it out rather quickly if we could get onto one of their machines. I'm not able to duplicate the issue. - DaveC_53879
The customer is NATing, so all clients have the same IP but different port s. I read about OneConnect but don't see how that would help. It looks like it's more of a resource saver and might make it worse, unless I'm reading it wrong. The site is really an application with many users other than the ones reporting problems. - Michael_Yates
If they Client is NAT'ing and appears to be coming from a single IP Address then the application of the OneConnect Profile should resolve your issue.
Without OneConnect enabled, persistence data is examined only in the first request of a Keep-Alive connection, so if multiple requests are sent on the same clientside Keep-Alive connection, LTM will persist them all to the same destination as the first unless a OneConnect profile is applied (even if logic contained in an iRule dictates otherwise).
To further translate. The OneConnect Profile will do a deeper inspection of each TCP Connection and handle them all as "different" connections in regards to persistence behavior. This should resolve your issue because each different connection is actually a different client rather than a different request from the same client.
The overview solution provides additional detail: Solution: SOL7208 - Overview of the OneConnect profile or http://support.f5.com/kb/en-us/solutions/public/7000/200/sol7208.html?sr=16914074
Pay particular attention to this area. It is the basis for my previous translation:
Content Switching
When a OneConnect profile is enabled for an HTTP virtual server, and an HTTP client sends multiple requests within a single connection, the BIG-IP system is able to process each HTTP request individually. The BIG-IP system sends the HTTP requests to different destination servers as determined by the load balancing method. Without a OneConnect profile enabled for the virtual server, the BIG-IP system performs load-balancing only once for each TCP connection. - DaveC_53879
Michael,
Thanks for the reply and the info. I think I understand what you're saying about the OneConnect, but I'm not sure that's my problem. I can see what look like exisitng sessions (unique IP/port ) sending persistence cookies, then for a few seconds stop sending persistence cookies, and then start again. As near as I can tell, these times when they fail to send their persistence cookie is when they have problems if they have problems, as they should if they get sent to another server. Do you have any idea what could be causing that and will the OneConnect maintain persistence whether or not they send the persistence cookie? I'm OK with everyone from that NAted IP going to the same physical server, as long as they can fail over to another if needed, so I'm trying not to staically set what server they hit.
Dave - Michael_Yates
Persistence will be set if it is not sent.
To say that OneConnect might solve your problem would be a total assumption based on the problem description. I would suggest a deeper investigation to determine if the connection that is not providing any persistence information is actually a new connection that looks like an existing connection, or if it is truly losing / not providing its persistence information.
A header logging iRule might help (I would only advise using this in a limited capacity for logging). This should help you determine if an existing connect or new connection is not providing a cookie (Search for the unique Client IP and Port Combinations).when HTTP_REQUEST { set LogString "Client [IP::client_addr]:[TCP::client_port] -> [HTTP::host][HTTP::uri]" log local0. "=============================================" log local0. "$LogString (request)" foreach aHeader [HTTP::header names] { log local0. "$aHeader: [HTTP::header value $aHeader]" } log local0. "=============================================" } when HTTP_RESPONSE { log local0. "=============================================" log local0. "$LogString (response) - status: [HTTP::status]" foreach aHeader [HTTP::header names] { log local0. "$aHeader: [HTTP::header value $aHeader]" } log local0. "=============================================" }
