kaoutar's avatar
kaoutar
Icon for Cirrus rankCirrus
Oct 16, 2019
parameter value with an a sequence of parameters values
hello,
We have an application which is going to accept a sequence of parameters with their values as one parameter's value, i need to know which parameter type should i assign to this parameter?
for example a parameter "user" in an URL /aaa admit as value the sequence parameters values "{"username":"admin","title":{"id":5},"firstName":"gjhgjhg","lastName":"gjgjjhg","zipCode":"20000","address":"adresse"}
Regards.
  • Hi kaoutar,
    Your sequence of parameters, looks like Json Array.
    If it's JSON parameters, you can assign JSON value to parameter's value.
  • thank you for your reply.
    totally, it is a JSON value but when i assigned it as a JSON value, the asm triggered an Illegal empty parameter value violation and when i allow it as an empty value the problem disappears. the same thing when i modify the parameter type.
  • Hello,
    can you please explain to me how the ASM recognize the parameters with JSON value within the POST Body ??
    • Lidev's avatar
      Lidev
      using the content-type or MIME media type in the request .
      for example:
      application/json
      application/x-javascript
      text/javascript
      text/x-javascript
      text/x-json
