Number of active and inactive vips
Hello All,
Is there anyway command which can tell number of active and inactive vips on LTM? Also real server attached to it?
I can count is manually but it is manual effort and will take a lot of time. So just wanted to confirm is there any way?
Thanks.
- kunjan
You can try cli tmsh list ltm virtual enabled/disabled and do grep
eg:
For disabled VS counttmsh list ltm virtual disabled| grep disabled | wc -lTo list enabled VS
tmsh list ltm virtual enabled | grep -B1 enabled - Amit585731
Kunjan,
Thanks for answer. But I am getting error 'Syntax Error: "-B1" unsupported option'. Any suggestion?
- kunjan
Are you running this on BigIP CLI? Which version of BigIP are you on? Can try egrep instead grep?
Can you also run grep --version ?
- Amit585731
Kunjan,
egrep also doesn't work.
Yes I am using CLI and code 11.5.1.
- kunjan
Interesting, it works for me in 11.5.1. Can you run
?grep --version - arpydays
try putting a space in i.e. '-B 1'
- Amit585731
Thanks Kunjan and arpydays... after putting space as suggested by arpydays it worked.
