david_MARTINEAU
Aug 16, 2012[Novice] Monitor Get request
I wiould like to make a monitor for check this URL on my F5 LTM6900
http://mon.serveur.com:10380/applicatif-uri/
1/ I can't make a specific port with predefined monitor TCP or HTTP
2/ I don't know how to insert in my specific port in my get request "send string" : GET /applicatif-uri/
How insert my specfic port on my monitor ?
Thanks a lot for your response.
BR,
David
FR
- if you leave the port in the monitor on * it is based on the pool member you apply this monitor on, so if you apply it on a poolmember ip:port where port is 10380 then it uses the port you want.
- david_MARTINEAU
Thanks a lot.
It works
