trx's avatar
Nov 13, 2009
NOT start with
Hello All,
Does anyone know the syntax for using "NOT start with" when doing a comparison with the URI?
ex)
This should do a 301 redirect if the URI does NOT start with "/Solutions Guide" and
starts with "Solutions" or "solutions"
if { !([HTTP::uri] starts_with "/Solutions Guide") and (([HTTP::uri] starts_with "/Solutions") or
([HTTP::uri] starts_with "/solutions")) } {
HTTP::respond 301 Location "http://[HTTP::host]/erp/Solutions"
log local0. "------301 redirect to Solutions VCM page.-----"
return
This code above does NOT work for some reason. What am I doing wrong?
Thanks!
Regards,
TRX
  • hoolio's avatar
    hoolio
    Hi Trx,
    not and ! are the same in iRules. A URI can't have a literal space in it--it must be URL encoded to %20.
    You could use a switch statement to do this:
         Check the requested URI
        switch -glob [HTTP::uri] {
           /[sS]olutions {
              log local0. "[IP::client_addr]:[TCP::client_port]: Matched /solutions check."
              if {! ([HTTP::uri] starts_with "/Solutions%20Guide") }{
         log local0. "[IP::client_addr]:[TCP::client_port]: Did not match /Solutions%20Guide"
    Aaron
