airhead218's avatar
airhead218
Dec 05, 2025
F5 mssql health monitor failing
I am having an issue when configuring an mssql health monitor. I see a successful connection in the database, but the advance debug logs are showing receive string not matching.
2025-12-03 09:50:40,269-0500 [id750_DBPinger-1686] - DB connect succeeded.
2025-12-03 09:50:40,269-0500 [id750_DBPinger-1686] - Query message: SELECT @@SERVERNAME AS ServerName, SERVERPROPERTY('ServerName') AS InstanceName, SERVERPROPERTY('ProductVersion') AS ProductVersion
2025-12-03 09:50:40,270-0500 [id750_DBPinger-1686] - Send Query success
2025-12-03 09:50:40,274-0500 [id750_DBPinger-1686] - Response from server: ServerName: 'icscwsql1' , InstanceName: 'icscwsql1' , ProductVersion: '16.0.4215.2'
2025-12-03 09:50:40,277-0500 [id750_DBPinger-1686] - Checking for recv string: ServerName
2025-12-03 09:50:40,279-0500 [id750_DBPinger-1686] - Analyze Response failure
Here is the configuration of the health monitor:
ltm monitor mssql icscwsql.mssql.mon {
    debug no
    defaults-from mssql
    interval 30
    password xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    recv ServerName:
    recv-column 1
    recv-row 1
    send "SELECT @@SERVERNAME AS ServerName, SERVERPROPERTY('ServerName') AS InstanceName, SERVERPROPERTY('ProductVersion') AS ProductVersion"
    time-until-up 0
    timeout 91
    username xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  • did you configure the monitor using gui or command line?
    use the gui and ensure there is no space after ":" in the receive string.
    and try without specifying the the receive column
  • Hello airhead218​
    I see a few members have asked some follow up questions to your post and I'd like to encourage you to answer those to allow our community to assist you. However, if you have already resolved outside of the community please update your post with how you solved the issue.
    Thank you for posting to our community!
    -Melissa
