Not able to upgrade
I have been trying to upgrade the BIG-IP 11.4.1 Build 685.0 Hotfix HF9 to the latest version but after importing the iso using the GUI the image is not shown in the available images so I don´t get to complete the upgrade. When I check the /shared/images directory the file is there. I also checked the file with md5sum to make sure the file is not corrupted.
[root@bigip1:Active:Standalone] images ls archive.pubkey.20130729.pem BIGIP-13.1.0.2-0.0.6.iso.md5 BIGIP-11.4.0.2384.0.iso BIGIP-13.1.0.2-0.0.6.iso.sig BIGIP-11.4.1.608.0.iso Hotfix-BIGIP-11.4.1-625.0-HF1.iso BIGIP-12.1.3.1-0.0.9.iso Hotfix-BIGIP-11.4.1-685.0-HF9.iso BIGIP-13.1.0.2-0.0.6.iso Hotfix-BIGIP-11.4.1-685.0-HF9.iso.crdownload
Can anyone help me?
- amintej
Cirrus
Are you sure the file was downloaded completed and OK ? According to the image the file extesion is : .crdownload and the MD5 Verified is no. Another strange thing is Hotfix usually are listed in
System ›› Software Management : Hotfix ListIs the image from that section ?
