New Application using different different backend applications with same URL
We have an application that has been running on Apache with a backend WebLogic instance.
The application URL for for example is https://application.abc.com There are 2 Locations setup in Apache which go to 2 different backend WebLogic instances.
https://application.abc.com/prod This goes to server prod.internal.abc.com:8000
https://application.abc.com/prod2 This goes to server prod2.internal.abc.com:8010
Is there a way within the F5 LTM to have one VIP, but based on what is after the main URL to go to different backend servers?
Thanks, Dave
- Kevin_Stewart
Employee
Absolutely. Here's what the iRule might look like:
when HTTP_REQUEST { switch -glob [HTTP::uri] { "/prod2*" { pool prod2_pool } "/prod*" { pool prod_pool } } }The important thing here is that you put the more specific entry first in the list. Starting with "/prod*" would match on everything. You'd then create two separate pools for your application servers.
You can also do the exact same thing with a traffic policy without touching iRules.
