Need suggestion on how to resolve the issue with a TCL error happening due to a HTTP::respond in another irule attached to the same Virtual Server
Hi, We have a virtual server which has four irules configured on it. The irule(irule) with the highest priority has a logic which would perform a HTTP::respond during the HTTP_REQUEST event with a status of 503 back to the client if the IP address matches one that is part of a configured blacklist of IPs specified in a datagroup. There is another irule(irule2) that is of lower priority that has a logic to remove a header and add it with a different value. HTTP::header remove testHeader HTTP::header add testHeader testvalue
What we are observing is that there are errors during the irule execution with stack trace as follows. 2014 Aug 8 11:48:54 server name local0 err err tmm1[4798]: 01220001:3: TCL error: irule2 - Operation not supported (line 1) invoked from within "HTTP::header remove "testHeader""
We have been looking at different threads in DevCentral and found the following links that were helpful.
https://devcentral.f5.com/questions/how-to-disable-irule-processing-on-keep-alive-per-request-when-using-httprespond https://devcentral.f5.com/wiki/irules.drop.ashx https://devcentral.f5.com/wiki/iRules.detect_prior_http_redirect_or_respond.ashx
We would like to know if performing drop after HTTP::respond in irule1 is a good practice. Additionally we would like to know what is the suggestion of a good practice for the solution in this scenario.
Thanks and Regards, Abhilash
- IheartF5_45022
Nacreous
Hi - You just need to issue "event HTTP_REQUEST disable" to prevent further iRule processing.
I don't think issuing a 'drop' after HTTP::respond would help - pretty sure you'd still get a TCL error, and in addition it might not send the response
- nitass
Employee
another approach is to move rule2 to HTTP_REQUEST_SEND event.
- nitass
Employee
e.g.
config root@(B6900-R69-S40)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 100.100.100.41:80 ip-protocol tcp mask 255.255.255.255 pool foo profiles { http { } tcp { } } rules { rule1 rule2 } source 0.0.0.0/0 source-address-translation { type automap } vs-index 5 } root@(B6900-R69-S40)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:80 { address 200.200.200.101 } } } root@(B6900-R69-S40)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm rule rule1 ltm rule rule1 { when HTTP_REQUEST { if { [HTTP::uri] ne "/" } { HTTP::redirect "http://www.google.com/" } } } root@(B6900-R69-S40)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm rule rule2 ltm rule rule2 { when HTTP_REQUEST_SEND { clientside { HTTP::header remove testHeader HTTP::header insert testHeader testvalue } } } trace [root@B6900-R69-S40:Active:Standalone] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 100.100.100.3(34895) <-> 100.100.100.41(80) 1407680420.8779 (0.0211) C>S --------------------------------------------------------------- HEAD / HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: 100.100.100.41 Accept: */* testHeader: 1234 --------------------------------------------------------------- New TCP connection 2: 200.200.200.40(34895) <-> 200.200.200.101(80) 1407680421.0482 (0.1696) C>S --------------------------------------------------------------- HEAD / HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: 100.100.100.41 Accept: */* testHeader: testvalue --------------------------------------------------------------- [root@B6900-R69-S40:Active:Standalone] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 100.100.100.3(34896) <-> 100.100.100.41(80) 1407680465.4821 (0.0006) C>S --------------------------------------------------------------- HEAD /something HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: 100.100.100.41 Accept: */* testHeader: 1234 --------------------------------------------------------------- 1407680465.4822 (0.0000) S>C --------------------------------------------------------------- HTTP/1.0 302 Found Location: http://www.google.com/ Server: BigIP Connection: Keep-Alive Content-Length: 0 ---------------------------------------------------------------
