RS_ms_321657's avatar
RS_ms_321657
Jun 14, 2017
Need help with using add_certificate_key_chain for F5 v11.5x during certificate import.
I am using the iControl package v12.1.00 to make the following calls to add a new certificate to a F5 v11.5.2. These are the calls that were being made initially: create_v2 set_default_profile But we also need a certificate bundle to be added as a cert chain - ms-intermediary-bundle.crt This was not being set.
I modified the code to include the add_certificate_key_chain call in the following order: create_v2 set_default_profile add_certificate_key_chain
I am creating the LocalLBProfileClientSSLCertificateKeyChain object using profile, key, empty passphrase and chain as "ms-intermediary-bundle.crt"
Can someone please guide me with correct usage of these API calls since the DevCentral documentation does not have sample code?
  • I also had this issue but never did make it work. Works fine with iControl Rest. There's an EA in 11.5.4 if I remember correctly. Give that a go?
    /Patrik
