RS_ms_321657
Jun 14, 2017Need help with using add_certificate_key_chain for F5 v11.5x during certificate import.
I am using the iControl package v12.1.00 to make the following calls to add a new certificate to a F5 v11.5.2.
These are the calls that were being made initially:
create_v2
set_default_profile
But we...
Jul 14, 2017
I also had this issue but never did make it work. Works fine with iControl Rest. There's an EA in 11.5.4 if I remember correctly. Give that a go?
/Patrik
