adminas's avatar
adminas
1 year ago
Solved
Need help with iRule based on host and path
Hello all.
I am trying to create an iRule that will choose a specific pool based on host and path. I tried the following code:
  if { [HTTP::host] equals "hostname_a"} {
    if { [HTTP::path] equals "/path" } {
      pool pool_a
        log local0. "URL : [HTTP::host][HTTP::uri] entered"
  if { [HTTP::host] equals "hostname_b"} {
        pool pool_b
According to Big-IP stats, the iRule gets executed but it doesnot direct the call to the pool (pool stats shows 0) specified although logging is invoked and I get the URL in the ltm logs.
Right after this script there is another one which gets executed and works as it should be. It specifies even more conditions for a series of pools and if none is matched then directs the call to the default pool specified there.
The problem is with the first one. I would like it to be executed and unless there is a match, then it should proceed to executing the second one.
If you can give me some advice it would be highly appreciated. Thank you.
  • Finally, problem solved! The reason was the order of execution for the 2 scripts. I donot really understand why this happens but when I placed the script in second place, everything is executed as expected. If you have any ideas please let me know.
    The problematic order which doesnot work is shown below:
    First script:
          pool pool_a
            pool pool_b
    Second script:
    if {[HTTP::has_responded]}{return}
        switch -glob [string tolower [HTTP::path]]
        default
                switch [string tolower [HTTP::host]]
                     "hostname_a"
                       pool pool_c
                       persist none
                      default
                             pool_z
    Anyway, thank you all very much for your time.
  • Hi. I am fine and hope the same for you!
    Thank you very much for your reply but the are already 3 working iRules that I cannot remove / convert and I need just an extra iRule to be executed in the beggining and move to the next script if no match is found. Its a production system and I cannot really experiment as I have no experience in policies.
    • JoseLabra's avatar
      JoseLabra
      Icon for MVP rankMVP
      And if you captured the traffic with tcpdump and test the iRule, you see the LB correctly?
      I remember a scenario with the same issue, the pool dont show the stats, but the LB its working.
      if was the case, open a ticket to support for more detail
      • adminas's avatar
        adminas
        Thank you.. I tried with tcpdump -nnvvi but cannot see any request going to the pool specified. I can see only health checking.
      • adminas's avatar
        adminas
        Thank you for your suggestion but there is no change.
  • Can u try with below example, u can add specific uri and host name. u can edit it based on your different host and path
        # Define pool selection based on host and path
        if { [HTTP::host] eq "example.com" } {
            if { [HTTP::uri] starts_with "/app1" } {
                pool pool_app1
            } elseif { [HTTP::uri] starts_with "/app2" } {
                pool pool_app2
                pool default_pool
        } elseif { [HTTP::host] eq "anotherexample.com" } {
            if { [HTTP::uri] starts_with "/service1" } {
                pool pool_service1
            } elseif { [HTTP::uri] starts_with "/service2" } {
                pool pool_service2
                pool default_pool
            # Fallback to a default pool if no match is found
            pool default_pool
    First script:
          pool pool_a
            pool pool_b
    Second script:
        default
                     "hostname_a"
                       pool pool_c
                       persist none
                      default
                             pool_z
