CHolston_15470's avatar
CHolston_15470
Aug 01, 2011
Need help load balancing between multiple ports...
Forgive me if this has been asked before, but here's my challenge:
I have an application that can run multiple instances of itself on different ports on a single host. What I'd like to do is have one VIP, say x.x.x.1:14000 route to multiple instances of my application on multiple servers, the pool might be something like this:
x.x.x.2:14000
x.x.x.2:14001
x.x.x.3:14000
x.x.x.3:14001
x.x.x.4:14000
x.x.x.4:14001
We've had some difficulty conceptualizing how this would work - is this possible?
Thanks!
-CIH
  • This would work just fine. Your Virtual Server would be x.x.x.1:14000 while your pool members would be the above.
  • Hi CIH,
    To add make sure you have address and port translation turned at the VIP.
    Bhattman
