InfoSec_38553
Apr 09, 2011More than one class for virtual IP
Hello all,
I wondering if possible to apply more than one class in ASM for one virtual IP?
Each class belong to specify URLs.
I want to do this to build different ASM policies from my application.
Thank you.
- mauro_59211
yes sure,
attention to the order of insertion, the more specific up and the minor specific ( example all traffic ) down.
this way you can create more 'web application, each linked to the path (or other criteria)
bye
mauro - InfoSec_38553
Hi mauro,
Thank you it worked with me.
I did it before without any result the reason was I picked URL with less violation.
Best Regards,
