Mattews's avatar
Mattews
Icon for Cirrus rankCirrus
Jan 21, 2019
Monitoring interfaces on F5
Hy to all,
i need to monitor interfaces where the traffic flows, i use sevone as a monitoring tool, where i can find these interfaces and how i can allow them to be monitored?
Thanks in advance, bye.
  • Hey Matteo
    In order to monitor the interfaces you can use either the MIB files which you can download from the BIG-IPs WebGUI or use the OIDs. You should be able to define that in the monitoring software.
    K13322: Overview of BIG-IP MIB files (BIG-IP 10.x - 13.x)
    To use the OIDs please use the following:
    • sys interface stat name - 1.3.6.1.4.1.3375.2.1.2.4.4.3.1.1
    • sys interface stat pkts in - 1.3.6.1.4.1.3375.2.1.2.4.4.3.1.2
    • sys interface stat pkts out - 1.3.6.1.4.1.3375.2.1.2.4.4.3.1.4
    • sys interface stat bytes in - 1.3.6.1.4.1.3375.2.1.2.4.4.3.1.3
    • sys interface stat bytes out - 1.3.6.1.4.1.3375.2.1.2.4.4.3.1.5
    • sys interface stat errors in - 1.3.6.1.4.1.3375.2.1.2.4.4.3.1.8
    • sys interface stat errors out - 1.3.6.1.4.1.3375.2.1.2.4.4.3.1.9
    • sys interface stat drops in - 1.3.6.1.4.1.3375.2.1.2.4.4.3.1.10
    • sys interface stat drops out - 1.3.6.1.4.1.3375.2.1.2.4.4.3.1.11
    • sys interface status - 1.3.6.1.4.1.3375.2.1.2.4.1.2.1.17
    These are just some of all the different OIDs you can use. You can also run an SNMP walk on the BIG-IP to see which information you want to monitor:
    [root@bigipcore02:Active:Changes Pending] config  snmpwalk -v2c -c public localhost 1.3.6.1.4.1.3375.2.1.2.4.1.2.1.17
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatus."1.1" = INTEGER: up(0)
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatus."1.2" = INTEGER: up(0)
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatus."1.3" = INTEGER: up(0)
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatus."1.4" = INTEGER: up(0)
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatus."1.5" = INTEGER: up(0)
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatus."mgmt" = INTEGER: up(0)
    [root@bigipcore02:Active:Changes Pending] config  snmpwalk -v2c -c public localhost 1.3.6.1.4.1.3375.2.1.2.4.4.3.1.3
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatBytesIn."1.1" = Counter64: 431764883
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatBytesIn."1.2" = Counter64: 601533207
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatBytesIn."1.3" = Counter64: 120
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatBytesIn."1.4" = Counter64: 339808188
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatBytesIn."1.5" = Counter64: 391200
    F5-BIGIP-SYSTEM-MIB::sysInterfaceStatBytesIn."mgmt" = Counter64: 256710269
    That is just interface information and statistics. Since interfaces are assigned to one or more VLANs, it could be more interesting to see the statistics and status of a particular VLAN. In those cases you can use the following OIDs:
    • sys vlan stat vlan name - 1.3.6.1.4.1.3375.2.1.2.13.6.2.1.1
    • sys vlan stat pkts in - 1.3.6.1.4.1.3375.2.1.2.13.6.2.1.2
    • sys vlan stat pkts out - 1.3.6.1.4.1.3375.2.1.2.13.6.2.1.4
    • sys vlan stat bytes in - 1.3.6.1.4.1.3375.2.1.2.13.6.2.1.3
    • sys vlan stat bytes out - 1.3.6.1.4.1.3375.2.1.2.13.6.2.1.5
    • sys vlan stat errors in - 1.3.6.1.4.1.3375.2.1.2.13.6.2.1.8
    • sys vlan stat errors out - 1.3.6.1.4.1.3375.2.1.2.13.6.2.1.9
    For example:
    [root@bigipcore02:Active:Changes Pending] config  snmpwalk -v2c -c public localhost 1.3.6.1.4.1.3375.2.1.2.13.6.2.1.1
    F5-BIGIP-SYSTEM-MIB::sysVlanStatVlanName."/Common/HA" = STRING: /Common/HA
    F5-BIGIP-SYSTEM-MIB::sysVlanStatVlanName."/Common/dmz" = STRING: /Common/dmz
    F5-BIGIP-SYSTEM-MIB::sysVlanStatVlanName."/Common/lan" = STRING: /Common/lan
    F5-BIGIP-SYSTEM-MIB::sysVlanStatVlanName."/Common/server" = STRING: /Common/server
    F5-BIGIP-SYSTEM-MIB::sysVlanStatVlanName."/Common/FW_F5_Linknet" = STRING: /Common/FW_F5_Linknet
    [root@bigipcore02:Active:Changes Pending] config  snmpwalk -v2c -c public localhost 1.3.6.1.4.1.3375.2.1.2.13.6.2.1.3
    F5-BIGIP-SYSTEM-MIB::sysVlanStatBytesIn."/Common/HA" = Counter64: 120
    F5-BIGIP-SYSTEM-MIB::sysVlanStatBytesIn."/Common/dmz" = Counter64: 393720
    F5-BIGIP-SYSTEM-MIB::sysVlanStatBytesIn."/Common/lan" = Counter64: 340095317
    F5-BIGIP-SYSTEM-MIB::sysVlanStatBytesIn."/Common/server" = Counter64: 601817438
    F5-BIGIP-SYSTEM-MIB::sysVlanStatBytesIn."/Common/FW_F5_Linknet" = Counter64: 433053417
    I hope this helps!
