Troy_93881's avatar
Troy_93881
Apr 01, 2011
Monitor using "grep"
All,
Looking for a little guidance. I would like to know if I can set up a monitor ( multiple monitors ) that would run a "grep" command and based on results -- mark a member up or down.
Appreciate and help anyone can provide,
  • hoolio's avatar
    hoolio
    Do you get the same delay when you SSH without the script? It's possible that the SSH server is configured to do a reverse lookup of the client IP. If so, you can disable that on the server by setting UseDNS to no in the sshd_config file.
    If you're using SSH from a monitor, you should do key based auth so you don't need to hard code a user/pass somewhere:
    https://help.ubuntu.com/community/SSH/OpenSSH/Keys
    Aaron
