Abdel_Bidar_837's avatar
Abdel_Bidar_837
Feb 14, 2012
Monitor availability of Virtual servers using SNMP
Hello,
I am trying to monitor our BigIP ( BIG-IP 10.2.2 Build 930.0 Hotfix HF3 ) through SNMP.
One of the report that I have develop is to monitor the availability of the Virtual Servers.
I am polling the following SNMP OID (ltmVirtualServAvailabilityState).
It only return the status on the common partition. Our F5 are configured with 2 partition.
I quickly searched on DevCentral and find this link
http://support.f5.com/kb/en-us/solutions/public/8000/500/sol8529.html?sr=19341834
This issue should have been fixed in release (9.4.2).
Can someone advise how to poll the status of the Virtualserver on the non common Partition?
Abdel
  • can you try this?
    [root@ve1023:Active] config  b version|grep -iA 1 version
    BIG-IP Version 10.2.3 112.0
    Final Edition
    [root@ve1023:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.79:80
       partition par1
    [root@ve1023:Active] config  b pool foo list
    pool foo {
       monitor all http
       partition par1
       members 200.200.200.101:80 {}
    [root@ve1023:Active] config  snmpwalk -v 2c -c public localhost F5-BIGIP-LOCAL-MIB::ltmVsStatusAvailState
    F5-BIGIP-LOCAL-MIB::ltmVsStatusAvailState."bar" = INTEGER: green(1)
    [root@ve1023:Active] config  snmptranslate -On F5-BIGIP-LOCAL-MIB::ltmVsStatusAvailState
    .1.3.6.1.4.1.3375.2.2.10.13.2.1.2
