Thamer_3789
Sep 23, 2012mobile device redirection
Hi All;
i want to apply this iRule to redirect the mobile devices traffic to another web site by detecting the "user agent" header...may you check it guys !!!!
if { [string tolower [HTTP::host][HTTP::uri]] contains "www.mysite.com" } {
if { [class match [string tolower [HTTP::header User-Agent]] equals mobile_device_types ] }{
HTTP::redirect "http://m.mysite.com"}
* Where " mobile_device_types " is a data group ...
Thanks in advanced
- nathe
Cirrocumulus
Thamer,
From a quick glance it looks fine. My suggestion would be use "contains" rather than "equals" as to match every user-agent that way in your data group sounds like a lot of work. You could then do generic variables like "mobile" in the data group. Unless of course you want to be very specific on the user-agents. Just my two penneth..
Hope it works
N - hoolio
As Nathan said, maybe something like this:when HTTP_REQUEST { if { [string tolower [HTTP::host]] equals "www.mysite.com" } { if { [class match [string tolower [HTTP::header User-Agent]] contains mobile_device_types ] }{ HTTP::redirect "http://m.mysite.com" } } }
Aaron - Thamer_3789
Thanks Guys :)
