Brandon
Aug 06, 2015Managment Interface
I would like snmp ntp to use the management interface instead it is using the DATA interface. I have a couple F5 that are using the management interface for SNMP and NTP. Why is that? The managment interface is working on both f5s.
- Vsevolod_Petrov
Hi Brandon,
Are SNMP Manager and F5 both in the same subnet?
If not you may need to specify a static route through the gateway in the mgmt network.This can be done via tmsh:
tmsh create /sys management-route lognet network 10.10.10.0/255.255.255.0 gateway 172.16.1.254Check out SOL13833 on askf5 for details.
Hope this helps.
