SL's avatar
SL
Icon for Cirrus rankCirrus
Jan 18, 2018
Maintenance page iRule
Hi All
I have created the below iRule for a Maintenance page
The page is loading successfully however. I am however the following issues: - The maintenance page is rendered even if there are servers available in the Pool, thus always showing the page - when accessing the site http://mysite.com/ the maintenance page loads, however when users are accessing stored pages that have URI included, example http://myexample.com/uri it tries to load the page and we get page cannot be displayed error. How do I resolve that if the user is using a URI or not that they get the maintenance page if servers are offline?
Any assistance will be greatly appreciated.
Thanx SL
  • It's a little hard to read your irule, are you able to copy the text rather than a screen shot?
    I would try to define exactly the pool you want to check, rather than relay on [LB::server pool] and specify the number of active members being less than one, as being the condition in the 'if' statement.
    [active_members my_pool] < 1
    Can you give an example of the URI requests that aren't working based on your code
  • You can't use the if statement where you have placed it inside the switch.
    if {[active_members [LB::server pool]] < 1 } {
      switch -glob ....
  • Miguel's avatar
    Miguel
    Has anyone found a solution for this issue? The problem for me is not the active pool is the path, usually refer to a file or folder (directory) on the webserver (for example “/folder/file.html”), to hostname shows all the images and background of the maintenance page but not using a path link.
  • Miguel's avatar
    Miguel
    Find out that adding extra lines with the path and the image makes the uri show the images on the path too.
    http://abc.com
    http://abc.com/xyz
      if { [active_members [LB::server pool]] < 1 } {
      switch -glob [HTTP::uri] {
        "/logo.png" {HTTP::respond 200 content [ifile get "logo"]}
    "xyz/logo.png" {HTTP::respond 200 content [ifile get "logo"]}
         default { HTTP::respond 200 content [ifile get index] noserver "Content-Type" "text/html" "Cache-Control" "no-cache, must-revalidate" }
  • I can recommend to use base64 for images...
    HTTP::respond 503 content {
    <!DOCTYPE HTML PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xml:lang="en" xmlns="http://www.w3.org/1999/xhtml" lang="en"><head>
    <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
    <title>Error 503 Service Unavailable</title>
    </head><body>
    <img src="data&colon;image/png;base64,yourbase64codehere" alt="Logo">
    <h1> Service Unavailable </h1>
    <p>The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.</p>
    </body>
    </html>
