Maintenance Page iRule
Dear Team,
We have one virtual server which consists of two pool members on it.
We would like to deploy the maintenance page on F5 if both the pool members are down.
We have an HTML page(which consists of the extension "maintenance.html") with us.
Could you pls let me know the iRule if we want to deploy the above "maintence.html" page on F5?
- muzammil_88686
Dear Team,
Also note that whenever the user want to access the www.test.com and all the subsequent requests i.e "/*" need to be redirected to maintenance page.
Thank you!
- nitass
Employee
what version are you running? have you tried sample irule in LTM Maintenance Page below? isn't it usable?
https://devcentral.f5.com/wiki/irules.ltmmaintenancepage.ashx - muzammil_88686
Thank you for your response!
Below is the version which we are running on LTM.
BIG-IP 10.2.1 Build 511.0 Hotfix HF3.
To be honest I m not familiar with the iRule what you have mentioned.
Could you pls suggest me one sample which I can follow?
Requirement:
Virtual Server IP: 192.168.1.1
Pool Name: test_pool
Pool Members: 10.1.1.1 and 10.1.1.2
HTTP page name do be deployed on LTM: "maintenance.html"
Condition: If both the pool members are down then user need to get the page "maintenance.html"
Pls let me know if you have any queries.
Thank you! - What_Lies_Bene1
The suggested sample is detailed at the URL Nitass has already posted.
- muzammil_88686
Thank you Steve for your response!
When I tried to follow the URL I have some doubts...could you pls suggest me on that.
1. Create the HTML for the maintenance page. It must be on one line, and all double-quotes must be escaped with backslashes.
Query1: For example, I have the below HTML code from "maint.index.html"(I mean ".HTML" format")
Maintenance pageSorry! This site is down for maintenance.
Do I need to save it as "maint.index.html.class"(I mean in ".class" format) and upload it in "/var/class/"
Thank you! - Chris_Miller
Altostratus
If you plan on going to v11 anytime soon, iFiles makes this much easier.
https://devcentral.f5.com/tech-tips/articles/v111-ndashexternal-file-access-from-irules-via-ifiles - muzammil_88686
Thank you Chris for your response and suggestion.
Unfortunately we do not have plan to go for v11 in the near future. - nitass
Employee
since your maintenance page is simple (no image inside), you may try something like this.[root@ve10:Active] config b virtual bar80 list virtual bar80 { snat automap pool foo destination 172.28.19.252:80 ip protocol 6 rules myrule profiles { http {} tcp {} } } [root@ve10:Active] config b rule myrule list rule myrule { when RULE_INIT { set static::maint_page "Sorry! This site is down for maintenance." } when HTTP_REQUEST { set maint_prefix "/maintenance.html" if { [HTTP::uri] equals "$maint_prefix" } { HTTP::respond 200 content $static::maint_page "Content-Type" "text/html" "Connection" "Close" return } if { [active_members [LB::server pool]] < 1 } { HTTP::redirect $maint_prefix } } } pool is down [root@ve10:Active] config b pool foo|grep -i pool\ member +-> POOL MEMBER foo/200.200.200.101:80 inactive,down bigip responds maintenance page instead [root@ve10:Active] config curl -iL http://172.28.19.252 HTTP/1.0 302 Found Location: /maintenance.html Server: BigIP Connection: Keep-Alive Content-Length: 0 HTTP/1.0 200 OK Content-Type: text/html Server: BigIP Connection: close Content-Length: 80 Sorry! This site is down for maintenance. - muzammil_88686
Thank you Nitass for your response!
From the iRule which you have suggested:
Users will not access any "/maintenance.html" page. If the user is trying to access "www.test.com" i.e "/*"(I mean www.test.com/abc, www.test.com/def, www.test.com/*...etc) it should show the below html page
Could you pls suggest if the above iRule suggested by you is still valid? - nitass
Employee
Users will not access any "/maintenance.html" page. If the user is trying to access "www.test.com" i.e "/*"(I mean www.test.com/abc, www.test.com/def, www.test.com/*...etc) it should show the below html pagethe redirection is done by the following part.if { [active_members [LB::server pool]] < 1 } { HTTP::redirect $maint_prefix }
