Domai_23823
Nov 30, 2017Maint page irule help
Hello I am trying to come up with a iRule for maint page. The requirement is -
- The page should be displayed when all the servers in the pool are down.
- The servers will be patched and will be rebooted one at a time and will be tested. During testing I need the users from one ip range to access the site but the maint page should be displayed for all the other users.
The below is what I came up with so far...with errors ofcourse..where am I going wrong?
if { [active_members [LB::server pool]] == 0 } {
HTTP::respond 200 content [ifile get "Maintenance_html"] noserver "Cache-Control" "no-store, no-cache"
return
elseif { [active_members [LB::server pool]] > 0 } {
check if client access from internal subnet
if { [IP::addr [IP::client_addr]/8 equals 10.0.0.0] } {
pool http_80
switch [HTTP::uri] {
default { HTTP::respond 200 content [ifile get "Maintenance_html"] noserver "Cache-Control" "no-store, no-cache"
- Samir_Jha_52506
Noctilucent
Small modification made. Please try.
when HTTP_REQUEST { if { [active_members [LB::server pool]] == 0 } { HTTP::respond 200 content [ifile get "Maintenance_html"] noserver "Cache-Control" "no-store, no-cache" return --Optional } elseif { [active_members [LB::server pool]] > 0 } { check if client access from internal subnet if { [IP::addr [IP::client_addr]/8 equals 10.0.0.0] } { pool http_80 } else { HTTP::respond 200 content [ifile get "Maintenance_html"] noserver "Cache-Control" "no-store, no-cache" } } }- Domai
Altostratus
That is it perfect thank you.
- Samir_Jha_52506
Noctilucent
can vote if irule solve ur purpose, so other can also refer. Thanks
- Andy_McGrath
Cumulonimbus
Update to f5_rock’s updated iRule to remove duplication, also you don’t need the else and pool http_80 lines if you are using the default pool assigned to the virtual server.
when HTTP_REQUEST { Pool members is less than 0 or client IP is not in subnet 10.0.0.0/8 return maintenance page if {[active_members [LB::server pool]] < 1 || [IP::addr [IP::client_addr]/8 ne 10.0.0.0]} { HTTP::respond 200 content [ifile get "Maintenance_html"] noserver "Cache-Control" "no-store, no-cache" } else { pool http_80 } }
