LTM VIP is sending reset packets and URL is not working.
We have an exchange webmail set up. Its a https URL but there's no certificate on LTM since backend server takes care of it.
Below is the VIP setup:
ltm virtual exchange2010-webmail.xxx.com-443 { destination 216.xx.xx.xx:https ip-protocol tcp mask 255.255.255.255 partition CoreSvcs pool webmail.xxx.com-443 profiles { /Common/analytics { } /Common/http { } /Common/tcp { } } source 0.0.0.0/0 source-address-translation { type automap } vs-index 4 }
Heres the pool, where members is marked up:
ltm pool webmail.ironmountain.com-443 { members { kcmtmgp01.na.xxx.com:https { address 192.x.x.x session monitor-enabled state up } } monitor /Common/https_443
But when we try accessing the URL from external network it doesn't work and keeps loading. Upon taking a packet capture I could see Reset packets from LTM VIP to Default Gateway on LTM.
- Renato_166638
is this the only VS that is not working? Did you check the nat configuration? - nathe
Cirrocumulus
Looks like it's a HTTPS virtual server but you're not offloading the SSL transaction. In that case remove the http profile from the VS configuration and try again.
Hope this helps,
N
- DevBabu
Cirrus
Please remove the HTTP profile from the configuration.
- dipta_03_149731
I tried removing the http profile but it still doesnt work.
- nathe
Cirrocumulus
OK, two further things, see https://support.f5.com/kb/en-us/solutions/public/13000/200/sol13223.html to log the RST reason. Also, try using SSLDUMP to check if it's the SSL handshake failing (I assume if you use TCPDUMP it passes the initial TCP 3 way handshake?)
- dipta_03_149731
Yes Nathan.
When I take a tcp dump I see the 3 way handshake and then some tCP Retransmision packets. Some TCP Duplicate and Keep Alive PAckets in middle and then Reset from LTM VIP to Default Gay=teway configured on LTM.
- nathe
Cirrocumulus
what about the SSL handshake? See https://support.f5.com/kb/en-us/solutions/public/10000/200/sol10209.html to detail capturing tcpdump and then using -r to read SSL handshake
- DevBabu
Cirrus
- Since you have configured SNAT automap, do you have floating self ip for the subnet reaching the pool member.
- Do you see serverside communication between LTM and the pool member in that request
