DifanZ's avatar
DifanZ
Icon for Cirrus rankCirrus
4 years ago
LTM two-way SSL authentication with a specific client cert, not CA cert
Hi experts,
I am trying to set up the SSL two-way authentication following this link https://support.f5.com/csp/article/K12140946#test. It is successful when I choose a CA certificate in the "Trusted Certificate Authorities" field in the Client SSL profile. However, this would authenticate anyone with the client cert signed by the CA (e.g., DigiCert), correct? How do I make it only accepts a specific client cert (e.g. xyz.example.com but not abc.example.com)? I have tried to specify the client cert in the field and the GUI accepts the setting but doesn't work.
Thanks!
  • xuwen's avatar
    xuwen
    when CLIENTSSL_HANDSHAKE {
    	if { [SSL::cert count] > 0 } {
    		if { [X509::subject [SSL::cert 0]] contains "CN=xyz.example.com" } {
    			return
    			log local0. "invalid client cert post, subject is: [X509::subject [SSL::cert 0]]"
    			drop
    • DifanZ's avatar
      DifanZ
      Thank you Xuwen! So it is not possible to do it in the GUI, and an irule would be required for this, correct?
      • xuwen's avatar
        xuwen
        sure, you can don't need irules, only use GUI,First, you need to let Client SSL profile the option "Client Certificate" value set to "Require",  then you can use a self-signed CA certificate(
        ), instead of using a public CA certificate, use the self-signed CA certificate to sign the client certificate to test the verification, and use curl --key xxx --cert xxx on the client side to test two-way ssl
