otsokume's avatar
otsokume
Apr 29, 2019
LTM SSL reset after clienthelo
Hello.
I have a very strange problems (or it seems to me) when i want to try load balance some appliances with https access. When i try to do an access i receive a reset from the server. When i do a ssldump i see this.
pre-master secret log file, generated by ssldump
24.25.4(443) 1 1 1556279563.8027 (0.0006) C>SV3.3(91) Handshake ClientHello Version 3.3 random[32]= ac f1 6d 22 4d d7 84 6c 5f 7c 75 b6 07 7d 7f d2 2c e0 38 31 13 53 45 79 77 d5 ab 0c 2c 70 e3 71 cipher suites Unknown value 0xc030 Unknown value 0xc02f Unknown value 0xff compression methods NULL 1 1556279563.8030 (0.0003) S>C TCP RST New TCP connection 2: 172.26.13.10(62099) <-> 172.24.25.4(443) 2 1 1556279564.4307 (0.0006) C>SV3.3(91) Handshake ClientHello Version 3.3 random[32]= bf 00 36 9d ba 9c 04 bb 53 5d b4 d8 bf 1a 1c f3 cb cd d4 03 bf d9 b2 9e 48 ea 3a 92 4e d4 f3 30 cipher suites Unknown value 0xc030 Unknown value 0xc02f Unknown value 0xff compression methods NULL 2 1556279564.4310 (0.0003) S>C TCP RST New TCP connection 3: 172.26.13.10(12313) <-> 172.24.25.4(443) 3 1 1556279564.5464 (0.0006) C>SV3.3(91) Handshake ClientHello Version 3.3 random[32]= 4e 9d 0f 22 83 bc d6 5c 58 1e d5 cd 84 00 4a 5a e4 cd 24 8d 12 af f3 6e 16 9d 5e b8 2e 46 7b 57 cipher suites Unknown value 0xc030 Unknown value 0xc02f Unknown value 0xff compression methods NULL 3 1556279564.5467 (0.0003) S>C TCP RST
I have change the ciphers to ALL but nothing. I have tried with a performancel4 vs and nothing.
Any idea? Thanks
  • nathe's avatar
    nathe
    otsokume,
    You should expect a ServerHello message after a ClientHello - the fact that you're getting a reset suggests that the cipher suites being offered by the client are not applicable on the F5 via the Client SSL Profile. I assume you've configured a Client SSL Profile and assigned this to the Virtual Server? What is the cipher string configuration on the Client SSL Profile?
    You can check what ciphers are supported based on the cipher string in your profile. If you go to the CLI and run this:
    tmm --clientciphers 'DEFAULT
    ' this should output all the ciphers (should you be using the DEFAULT cipher string of course. If you've amended this then amend the command aswell.
    Your clienthello suggests these two cipher suites are supported only "ECDHE_RSA_WITH_AES_256_GCM_SHA384" and "ECDHE_RSA_WITH_AES_128_GCM_SHA256" - so you need to verify your SSL profile.
    Also see these links for further help: SSL Profiles Part 4 and Troubleshooting SSL/TLS
    Hope this helps,
    N
