Sab
Apr 12, 2016LTM sends monitoring Porbes , which interface ip address will it take
Guys need help in understanding this , When LTM sends monitoring Porbes (tcp health monitor), which ip address will it take as Source-ip Self ip of Floating IP. My LTM is a fully licenced vm edition configured in a cluster .
Kindly advice
- Domai
Altostratus
Both the active and Stby devices will you their self IP's to monitor...the pool member.
- Sab
conf as requested
- Domai
Altostratus
The state of both the pool members are "UP", from the above screenshot...Did you change it to TCP to test? Can you send the custom monitor code as well? The one that does not work if you made the change. If you did not make the change then the pool is showing that the pool members are up...recheck again.
