nikzin_341815's avatar
nikzin_341815
Apr 03, 2019
LTM Monitor Receive String
Hello, my ltm monitor receive string doesn't work. Problem is that i am only interested in one line. Here is the whole output of the receive sting:
{ "returnCode": 0, "version": "9.0.0.37265", "product": "match", "command": "list project", "errorMsg": "OK", "projectList": [ { "projectId": "4711", "author": "Sam Sample", "description": "Test", "title": "Example", "configurationTime": "Date:Time", "state": "RUNNING" } ] }
For me only the line with: "state": "RUNNING" is interesting. When this is changing pool member should be go offline and no traffic will be forwarded. I have tested with differnet wildcards e.g.:
.\"state\":\"RUNNING\".
But it doesn't work.
Thankfull for any help.
Cheers, Nikolas
  • Hi,
    You can also try:
    "state":\s?"RUNNING"
    with "\s?", my regular expression will accept the following expression (with and without space):
    • "state": "RUNNING"
    • "state":"RUNNING"
    Regards
  • The receive string uses regex to match, however just put in the following which should match:
    "state": "RUNNING"
