cawong23_136311
Altostratus
Apr 12, 2017LTM https health monitor how to monitor a page with disabling HEAD
Hi F5,
As titled, we checked that the http (port 80) monitor is ok, but server https is failed.
We tried curl the URL but only 403 can be shown, so the the pool will never go green.
Do you guys have any idea?
Many Thanks!
- IainThomson85_1
Cumulonimbus
403 Suggests that you are forbidden from accessing the page/server. Have you completed any diagnostics with curl etc ? Can you share your outputs ?
Can you share your current configuration?
- oscarnet_69487
HI
check it
Testing an HTTPS monitor with user authentication from the command line
and check check you monitor config
ltm monitor https /Common/check_HTTPS_Monitor { adaptive disabled cipherlist DEFAULT:+SHA:+3DES:+kEDH compatibility enabled defaults-from /Common/https destination *:* interval 5 ip-dscp 0 recv "Site is Up" recv-disable 403 send "GET /check_site_alive/ \\r\\n\\r\\n" time-until-up 0 timeout 16 }have a good day!
