Justine_313324's avatar
Justine_313324
Sep 11, 2017
LTM and GTM on the same box on both site then use GTM sync
Hi everyone! I would like to ask if using a single box on both GTM and LTM. My design is I have two F5 appliances with 2 modules(GTM and LTM) that will be located on each DMZ site(2 DMZ sites). I would like to use GTM for global load balancing and LTM for the local load balancing of the app/web servers. Since I have two appliances, I would like to GTM sync the two appliances.
Question: Is this possible?
Thanks!
    • Justine_313324's avatar
      Justine_313324
      Would it not introduce some errors? What are the keynotes for this?
    • eben_259100's avatar
      eben_259100
      No it will not. keynotes: 1. ensure capacity planning is done right per the model you have. 2. config is same as when you have GTM AND LTM on separate boxes. you need to do bigip_add for the other GTM/LTM and when you are done with configuring the first GTM you can sync its config from the second GTM. gtm_add . this cmd should be from the second unconfigured GTM.
      HTH Eben.
      • Eslam_Sayed's avatar
        Eslam_Sayed
        Thanks a lot .. I just need to make sure if it will need to have extra license like Vcmp or no need ?
  • eben's avatar
    eben
    Hi Justine,
    Yes it is.
    Regards
    Eben.
    • eben's avatar
      eben
      HTH Eben.
