Loadbalance SMTP relay on F5 and exchange 2010 (Urgent help needed)
We are trying to use two Hub Transport servers to load balance all internal application relay. The roblem I have run into. All connections made from F5 automatically connects to the default receive connector rather than the custom receive connector.Also we want to see the client ip addresses instead of bigip VS server ip as source.
I have tried to disable SNAT and i am not ablr to telnet SMTP server.
I would really appriciate your help.Sorry to bother you guys i need to fix this relay issue ASAP.
- gg234_32466
We are running bigip 10.2.4 with LTM
- Cory_50405
Noctilucent
Disabling SNAT means that your hub transport servers would see the communications as if they were coming from the actual client IP addresses. Hub server response traffic to the clients would need to return through the F5 in order for the connections to work. Otherwise, the client would see return traffic from a different IP address and the connections would never establish. You'd need some type of policy based routing if the LTM isn't directly in the communications path.
Regarding the custom connector you mention, is that a separate IP address on the hub transport server or are both listening on the same IP address?
- gg234_32466
thanks for your help and both are listening on the same ip address
- gg234_32466
I need to check exchange engineer to do the above policy based routing
- Cory_50405
Noctilucent
I would think the policy based routing would best be done via some router/firewall within your network. If no such device exists, the hub transport server routing may be able to be modified. So much depends on the setup and complexity of your environment though. Sorry I can't be of more help.
