Stefan_Magnus_L
Aug 27, 2013Limit HTTP request body size
Is there a way to limit the size of the HTTP request bodys that bigip forwards to a backend server? As a security measure, and in order to prevent running out of diskspace, we want to prevent users from uploading files larger than 10MB.
- Beinhard_8950
it should be possibly to use the content-lenght header if I´m not to rusty after vacation =)
but of course it could be simpler to do it in the servers I guess (depending of course of your setup)
Br
Beinhard
- Ido_Breger_3805Historic F5 AccountThis is very easy to achieve using ASM.
- Stefan_Magnus_L
Ok, cool. Where can I find documentation on this? - Stefan_Magnus_L
The content length header can be spoofed (or even not provided), so I'm afraid that is not an option
