Robert_Roman_14's avatar
Robert_Roman_14
12 years ago
Solved
LDAP Authentication Issue - Very WEIRD!
I have been implementing LDAP authentication for the management of our F5 Infrastructure and I have encountered a very weird problem: I can log into the GTM terminal with AD credentials, however, when I try to log in to the web management GUI, it says that the login failed. I want to be able to log in to both the GUI and the terminal with AD credentials. Anyone have a clue what to possibly check to figure out why this isnt working on the GUI?
  • This is such a weird situation. It works on both LTMs and our second GTM flawlessly. I can log in to the terminal using putty fine with my Active Directory credentials. The only part that is failing is the GUI authentication.
    • Robert_Roman_14's avatar
      Robert_Roman_14
      10.2.2. We have since figured out the error as it was a problem on the ldap box itself even though they said it was not initially.
