LAB problem: BIG-IP VE + VMware Workstation + Ubuntu
Hi!
I am trying to set up a lab to prepare for my 201 exam. This is my setup:
OS: Ubuntu 14.10, 64 bit Processor: Intel Core I5-4570 [email protected] x4 Hypervisor: VMWare Workstation 12.1.0 BIG-IP VE: 11.3.0.39.0-scsi
If I'am trying to start big-ip ve in VM workstation as a "guest operating system" == Other 64-bit (default setting), VMware workstation shows an error with message:
"This virtual machine is configured for 64-bit guest operating systems. However, 64-bit operation is not possible.This host supports Intel VT-x, but Intel VT-x is disabled.Intel VT-x might be disabled if it has been disabled in the BIOS/firmware settings or the host has not been power-cycled since changing this setting.(1) Verify that the BIOS/firmware settings enable Intel VT-x and disable 'trusted execution.'(2) Power-cycle the host if either of these BIOS/firmware settings have been changed.(3) Power-cycle the host if you have not done so since installing VMware Workstation.(4) Update the host's BIOS/firmware to the latest version.For more detailed information, see http://vmware.com/info?id=152."
When I try with "guest operating system" option set as "Other", VM Wrokstationd loads GRUB and shows message:
"This kernel requires an x86-64 CPU, but only detected an i686 CPU. Unable to boot - please use a Kernel appropriate for your CPU"
Please advise how to handle this problem.
Have you checked the options in BIOS on your host? If you enable Virtualization support there it should start.
/Patrik
- Kuba_Chal_24018
@Patrik Jonsson thanks for help! I managed to run it. I had to change bios settings and enable VT-x ( hidden in security options in BIOS in my HP EliteDesk PC)
