Morten_Marstran's avatar
Morten_Marstran
Oct 31, 2017
Issues with HTTP/2 and web acceleration
I am testing HTTP/2 for a virtual server that already has a compression and web acceleration profile in use.
HTTP/2 works fine when I add the relevant profile, although stylesheets fail to load.
Instead of a stylesheet I get a "HTTP status code 000".
I tried deleting the contents of the ramcache, but did not help.
It only works when i remove the web acceleration profile from the virtual server.
Has anyone experienced anything similar?
Kind regards,
Morten
  • UPDATE:
    F5 created an Engineering Hotfix to solve the issue. You can ask for it by referencing ID696755
    • Morten_Marstran's avatar
      Morten_Marstran
      Hi!
      Yes, F5 created an Engineering Hotfix to solve the issue. You can ask for it by referencing ID696755
      Best Regards, Morten
