Jonathan12's avatar
Jonathan12
May 05, 2020
Issues updating a fastl4 profile using Python SDK
I have a very small/simple fastl4 profile based on the default. I want to disable syn-cookie-enable, which is pretty easy from the CLI:
modify ltm profile cookie-all-fastl4 syn-cookie-enable disable
This results in the following:
ltm profile fastl4 cookie-all-fastl4 {
   app-service none
   defaults-from fastL4
syn-cookie-enable disabled
I have not had much success trying to do the same with the Python SDK.
If I use the load/update method it will create an entirely custom configuration.
cookie = bigip.tm.ltm.profile.fastl4s.fastl4.load(name='cookie-tcp-fastl4')
cookie.synCookieEnable='disabled'
cookie.update()
The result is this:
ltm profile fastl4 cookie-tcp-fastl4 {
   app-service none
   client-timeout 30
   description none
   explicit-flow-migration disabled
   hardware-syn-cookie disabled
   idle-timeout 300
   ip-df-mode preserve
   ip-tos-to-client pass-through
   ip-tos-to-server pass-through
   ip-ttl-mode decrement
   ip-ttl-v4 255
   ip-ttl-v6 64
   keep-alive-interval disabled
   late-binding disabled
   link-qos-to-client pass-through
   link-qos-to-server pass-through
   loose-close disabled
   loose-initialization disabled
   mss-override 0
   other-pva-clientpkts-threshold 2
   other-pva-offload-direction bidirectional
   other-pva-serverpkts-threshold 1
   other-pva-whento-offload after-packets-per-direction
   priority-to-client pass-through
   priority-to-server pass-through
   pva-acceleration full
   pva-dynamic-client-packets 1
   pva-dynamic-server-packets 0
   pva-flow-aging enabled
   pva-flow-evict enabled
   pva-offload-dynamic enabled
   pva-offload-dynamic-priority disabled
   pva-offload-initial-priority medium
   pva-offload-state embryonic
   reassemble-fragments disabled
   receive-window-size 0
   reset-on-timeout enabled
   rtt-from-client disabled
   rtt-from-server disabled
   server-sack disabled
   server-timestamp disabled
   software-syn-cookie disabled
   syn-cookie-mss 0
   syn-cookie-whitelist disabled
   tcp-close-timeout 5
   tcp-generate-isn disabled
   tcp-handshake-timeout 5
   tcp-pva-offload-direction bidirectional
   tcp-pva-whento-offload embryonic
   tcp-strip-sack disabled
   tcp-time-wait-timeout 0
   tcp-timestamp-mode preserve
   tcp-wscale-mode preserve
   timeout-recovery disconnect
This is undesirable because now I have to manage changes in both the default fastl4 profile and this cookie profile as well.
If I try to use the modify method I get an error:
cookie=bigip.tm.ltm.profile.fastl4s.fastl4.modify(name='cookie-tcp-fastl4', synCookieEnable='disabled')
 File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/f5/bigip/resource.py", line 411, in modify
   self._modify(**patch)
 File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/f5/bigip/resource.py", line 392, in _modify
   self._prepare_put_or_patch(patch)
 File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/f5/bigip/resource.py", line 425, in _prepare_put_or_patch
   update_uri = self._meta_data['uri']
KeyError: 'uri'
I'm not sure why the syntax is wrong, I use a very similar syntax for all sorts of other Resources.
