Issue with possible conenction not dropping between requests for device
Here is the config
General Properties Name H1PRP_VL Partition Common Destination Type: Host Network Address:
10.24.57.124 Service Port
0 * All Ports Availability
State
Enabled Configuration: Advanced Type
Standard Protocol
TCP Protocol Profile (Client)
tcp Protocol Profile (Server)
( Use Client Profile ) OneConnect Profile
None NTLM Conn Pool
None HTTP Profile
None FTP Profile
None Stream Profile
None XML Profile
None SSL Profile (Client)
None SSL Profile (Server)
None Authentication Profiles Enabled Available
ssl _ cc _ ldap ssl _ crldp ssl _ ocsp RTSP Profile
None Diameter Profile
None SIP Profile
None Statistics Profile
None VLAN and Tunnel Traffic
All VLANs and Tunnels SNAT Pool
Auto Map Rate Class
None Traffic Class Enabled Available
Connection Limit
0 Connection Mirroring (May degrade performance when enabled.) Address Translation Enabled Port Translation Enabled Source Port
Preserve Clone Pool (Client)
None Clone Pool (Server)
None Last Hop Pool
None
Load Balancing Default Pool
H 1 ENG _ P 2 DA Default Persistence Profile
None Fallback Persistence Profile
None Update iRules Manage... Name No records to display. HTTP Class Profiles Manage... Name No records to display.
General Properties Name H1ENG_P2DA Partition Common Availability Available (Enabled) - The pool is available Configuration: Advanced Health Monitors Active Available
Anon _ HTTP _ 80 <<
ANON _ HTTP _ 80 _ LONG Anon _ HTTPS _ 443 Anonymous _ Snoop EnterpriseRx SMB _ FIle _ Share Availability Requirement Health Monitor(s) All Allow SNAT
Yes Allow NAT
Yes Action On Service Down
None Slow Ramp Time seconds 10 IP ToS to Client
Pass Through IP ToS to Server
Pass Through Link QoS to Client
Pass Through Link QoS to Server
Pass Through Reselect Tries
0
