Shane_Terrick_9
Aug 26, 2013Issue with possible conenction not dropping between requests for device
Here is the scenario
Start with 2 Welch Allyn devices, device A and device B
Start with two facilities, Facility 1 and Facility 2
flow is: Device -> F5 -> WebSphere App Server -> F5 -> Device
F...
Kevin_Stewart
Employee
Aug 26, 2013Check to make sure you have OneConnect disabled. I have seen it cause similar issues.
I would say this also depends on the iRule and/or HTTP class used to flip traffic between the pools. Can you share your config? Do you have any "match across virtual" persistence settings?
