drhaskins's avatar
drhaskins
Oct 30, 2020
Issue with External monitor returning value
I am attempting to write an external monitor to determine which of our three databases is the "master." We need to first ssh to the server and then run a command. This command should return either a 'true' or 'fals'
#!/bin/sh
# Name of the pidfile
pidfile="/var/run/$MONITOR_NAME.$1..$2.pid"
# Send signal to the process group to kill our former self and any children
# as external monitors are run with SIGHUP blocked
if [ -f $pidfile ]
then
  kill -9 -`cat $pidfile` > /dev/null 2>&1
fi
echo "$$" > $pidfile
# Remove the IPv6/IPv4 compatibility prefix
node_ip=`echo $1 | sed 's/::ffff://'`
/bin/expect<<EOF
  log_file -noappend /var/tmp/mongo_status.log
  spawn /bin/ssh [email protected]
  sleep 1;
  expect "password:"
  send "***********"
  expect "svc_f5"
  send "/bin/mongo -u ******** -p ******** --authenticationDatabase admin --eval 'printjson(db.isMaster())'|grep 'ismaster' | cut -c15-18\r"
  sleep 4
  send "exit\r"
EOF
status=$?
echo "$status"
if [ $status -eq 0 ]
then
# Remove the pidfile before the script echoes anything to stdout and is killed by bigd
  rm -f $pidfile
  echo "up"
fi
# Remove the pidfile before the script ends
rm -f $pidfile
I have been unable to determine the the value from expect.
Any suggestions would be most appreciated.
Thank you
  • You need to understand the behaviour of External monitors and stdout
    K7444: Requirements for external monitor output
    Custom external monitors must observe the following output requirements:
    • If a server meets the external monitor criteria, the external monitor must send data to stdout.
    • Note: Any data on stdout results in an Available status. The data does not have to be specific to the condition of the server.
    • Note: Any standard output stops the script from running. To ensure that the necessary operations occur, F5 recommends that you clean up any temporary files, perform logging, etc., before the system performs the standard output operation.
    • If a server fails to meet the external monitor criteria, the external monitor must not send any data to stdout.
    Looking at your script, you have
    status=$?
     echo "$status"
    This will terminate the script here, and mark the monitor as "Available".
    If you need to log something from the script for development purposes, use *logger* to log into /var/log/ltm
