dsanders1979_24
Jul 03, 2007Issue redirecting from HTTP to HTTPS and then balance to different pools based on suffix
I have a scenario where I have the same base URL, however multiple websites with different names, i.e. www.abc.com/production1/enhancedlogin.asp , and www.abc.com/test1/enhancedlogin.asp.
I currently have two virtual servers set up for this, one for Port 80 traffic, and the other for Port 443 traffic.
I would like all requests that come in for the host domain http://www.abc.com to be redirected to https://www.abc.com, and also redirected to whichever pool cooresponds with the suffix (https://www.abc.com/production1 >>> pool_1, while https://www.abc.com/test1 >>> pool_2)
I'm new to creation of IRules and was hoping to know, if this is possible, and if there are any suggestions / sample irules anyone is aware of that could help with this cause.
Thanks in advance!
- Chris_Seymour_1Historic F5 AccountThis should be no problem. First you will want to redirect all traffic with the below simple iRule that is available on the codeshare.
HTTP::redirect "https://[HTTP::host][HTTP::uri]" }
Next you will need the commands to direct the client based on their URI to the correct pool
if { [HTTP::uri] starts_with "production1" } {
pool pool1
elseif { [HTTP::uri] starts_with"test1" } {
pool pool2
Good luck!
obi chris kenobi
