Yasir_Memon_999's avatar
Yasir_Memon_999
Aug 02, 2012
Issue During Upgrade From 9.4.8 to 10.2.3 Please Help
Dear All,
I am facing an issue when i am going to upgrade my F5 1500 LTM i am getting an error. Please find the below given error.
[admin@localhost:Active] images image2disk --instslot=HD1.1 --format=volumes BIGIP-10.2.3.112.0.iso
warning: copy failed (/tmp/FMYq2S1LdM/mfg.pattern.sh): No such file or directory
info: Repository tm_install version/release is 2.7.1/23.0
info: System tm_install version/release is 2.5.2/7.0
info: Updating system tm_install files from BIGIP-10.2.3.112.0.iso
7358 blocks
info: Installer on image is newer, reexec
info: Running updated installer.
info: Platform id is C36
warning: System has no isoinfo utility; guessing that BIGIP-10.2.3.112.0.iso is a product image.
error: tm_install::TMOS::TMOS_binary: cannot find program: pvs
searched:
/usr/sbin/pvs
Called from tm_install::Disk::pv_scan
Terminal error: You cannot specify the target location when using the format option.
Please help in this regards...
Yasir Memon
  • nathe's avatar
    nathe
    Yasir,
    See http://support.f5.com/kb/en-us/solutions/public/12000/500/sol12561.html
    Basically, remove the instslot option as this is no longer required.
    Hope this helps,
    N
  • Dear Nathan,
    Thanks alot many many thanks.... this works and make my life easier :)
    Best Regards
    Yasir Memon
