amadalijnscka's avatar
amadalijnscka
Apr 02, 2025
Install rpm packages using tmsh
Hi everyone,
I’m trying to install the F5 Cloud Failover Extension (CFE) on my BIG-IP system, but I’m struggling to properly install the RPM package so that it appears under iApps → Package Management LX.
Here’s what I have done so far:
  • Successfully downloaded f5-cloud-failover-2.1.3-3.noarch.rpm
  • Tried installing the package using rpm -ivh f5-cloud-failover-2.1.3-3.noarch.rpm.
  • Restarted the REST API service using tmsh restart sys service restjavad.
Despite these steps, the package does not appear under iApps → Package Management LX
Also when I reinstall the package I get "package f5-cloud-failover-2.1.3-3.noarch is already installed"
Is there a specific command to install RPM packages via TMSH so they are properly recognized? Or is there another step required to make the extension available?
Thanks in advance for any insights!
