Julio_Flores_15
Aug 18, 2017ISO8583 Application Load Balancing
ISO8583 Application customer came to me with a requirement to load balancing with LTM, i understand need to use some irules, or exist some IAPP to config this?
- cjunior
Nacreous
Hi Julio, I can't remember a ready iApp to do this job.
But in the past, I've manually add a mblb profile to virtual server (e.g.
) and have associated this iRule to balance packet by packet to all active pool members:modify ltm virtual vs_iso8353 profiles add { mblb }when CLIENT_ACCEPTED { TCP::collect } when CLIENT_DATA { catch {LB::detach} TCP::release TCP::notify eom TCP::collect } when LB_FAILED { if { [active_members [LB::server pool]] > 0 } { LB::reselect pool [LB::server pool] } } when SERVER_CONNECTED { TCP::collect } when SERVER_DATA { TCP::release TCP::notify eom TCP::collect }Regards.
- Julio_Flores_15
Thanks for the information, I will make tests with what you send me, thanks again
